Here it is guys the upgrade that will be taking place soon and just wanted to share info and my experience with it.
Old System Setup
http://www.overclockers.com/forums/...TER-BUILD-CORSAIR-AIR-540?highlight=build+log
***BEFORE***
***AFTER***(Upgrade)
THE HARDWARE
THE CASE: PHANTEKS ENTHOO PRO M (Titanium Green) (NEW)
THE MOTHERBOARD: EVGA X99 Micro microATX
THE PROCESSOR: Intel Core i7‑5820K 3.3 GHz LGA 2011‑v3
THE GRAPHIC CARD: EVGA GeForce GTX 980 Ti CLASSIFIED
THE RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4 DRAM 3000MHz
HARD DRIVES: Seagate 3TB
SOLID STATE1: PNY 240GB SSD CS2111-XLR8
SOLID STATE2: Crucial 240GB M500
SOLID STATE3: Crucial 240GB M500
POWER SUPPLY: EVGA SuperNova 1000G2
THE AUDIO: CreativeLab Sound Blaster Zx
THE WATER COOLING PARTS
PUMP: EK-XTOP Revo D5 PWM
CPU BLOCK: EK-Supermacy EVO
RESERVOIR: EK-XRES-100-REVO D5 Top/Reservoir - Acetal (NEW)
RADIATORS: 2x Magicool 240 Slim G2 Radiator MC-RAD240G2
GPU BLOCK: EK GTX 780Ti Classified Water Block (GTX-980Ti)
VALVE: 1x EK-AF Ball Valve (10mm) G1/4 Nickel
ROTARY: 2x EK-AF Extender Rotary
FITTINGS: 16x EK-ACF Fitting 10/16mm Nickel
CAP: EK-CSQ Plug G1/4 (for EK-Badge) - Nickel
3-WAY BLOCK: EK-AF T-Splitter 3F G1/4 - Nickel
90* ANGLED FITTING: 4x Angled 2 x 45 G1/4 Fitting (NEW)
EXTENDER: EK-AF Extender 20mm M-F G1/4 (NEW)
BRACKET: EK-UNI Pump Bracket (120mm Fan) Vertical (NEW)
RAD FANS: 4x Nidec Servo GentleTyphoon 120mm Case Fan 2150 RPM PWM Fan (NEW)
PSU PLUG: EK-ATX Bridging Plug (24 Pin)
TUBING: EK-Tube ZMT Rubber Tubbing Matte Black (NEW)
COOLANT: PrimoChill ICE Water Cooling Fluid (32 oz.) - Clear
ACCESSORIES
MONITOR 1: HP Pavilion 25bw IPS LED LCD
MONITOR 2: ACER H233H 23” LCD
SPEAKERS: Klipsch THX,
KEYBOARD: Logitech G710+ Mechanical Keyboard
MOUSE: Logitech G9 Laser
WEBCAM: LifeCam HD-5001
Old System Setup
***BEFORE***
THE HARDWARE
ACCESSORIES
