Well tbh it is, im pretty sure its forming a bit of a hotpocket at the bottom/ the fans aint working as well as they could be. I will do the bottom mod once i have the dremmel. but for now it isnt needed. My temps are so good im almost too lazy to bother.
Ok so a little update peeps! I went and did an overhaul of my loop! Wanted to tidy up the massive loops at the bottom and generally cut down the amount of tubing.
i didn't bother to do a whole series of pics just the end product ( leak testing.)
This was all in prep for i46 ( massive lan party. So wanted it all nice and neat by then.)
I am also going to replace the straight comp fittings to 45 c ones ( the two from the cpu to gpu)
