Hello all!
I've been assembling my own gaming PCs for over a decade, usually in the "bang for buck" range of things. But now I'm older, actually have a solid income, and have managed to avoid picking up expensive things like a "wife" or "children," so I've rapidly moved up the performance scale. Because screw it, why not, right? (famous last words)
I've got a machine that runs all the pixels real good already:
Core i5-6600k, presently at 4.5GHz. Cooled with Corsair H100i.
Gigabyte G1 Gaming GTX 1080
32GB RAM, DDR 3200 EVGA
The hodgepodge collection of drives accumulated over the years. Hey, they all still work fine!
Crucial m4 120GB SSD (OS), 500GB Samsung 840 EVO, 500GB Samsung 850 EVO, WD Black 1.5TB HDD
Right now it's all sitting in a Corsair Carbide 500R. A lovely case that has served me well.
But I want to take this hobby up to the next level, and I'm pretty sure I'm going 0-60 in 2.8 here but the journey will be a fun one. It's time for my first watercooling rig. Also, I've always had a "function over form" sort of building experience, so have usually had ugly, ugly machines. This time, I want to go full sexy. Right now I'm in the preliminary planning stage. The tentative plan so far:
Case: Phanteks Enthoo Luxe. Good watercooling support, good cable management, highly modular, fancy controllable RGB LED lighting, looks good... all for $150? Yes please!
Motherboard: ASUS ROG Maximus Formula VIII. Hoo boy that's a pricey motherboard. Largely an aesthetic choice, but it's also a solid motherboard packed with features. Solid black with controllable RGB lighting that are compatible with the Luxe case lights so it'll all coordinate via software. Built-in water cooling block for the VRM because why the heck not. I could go with the Hero Alpha and still get the Aura lighting control, but I don't like the look as much and at this point I'm spending a crapton on the build so what's an extra $80 on a motherboard that should hopefully last for quite some time?
Top Radiator: Alphacool UT60 420mm. Big as will fit up there.
Front Radiator: Alphacool XT45 240mm. Bottom mounting this one seems to be another possibility.
A ton of radiator space for 1GPU and 1 CPU, but I figured that more radiator allows for slower fans and less noise, and also gives me a good basis for future upgrades in case I want to add another 1080 at some point, or SLI in the 11XX/12XX/ti range a few years down the line. I could downgrade to a 360 and be fine, but the 360 is literally eight dollars cheaper. 280 or 240 on top would save a bit more, so maybe comments on 280x60 + 240x45 being sufficient, or not, for CPU + SLI GPU + overclocks will help me out.
Fans: Phanteks SP series (140/120SP)
CPU Block: EK Supremcy EVO - Green?
GPU Block - EK G1 GTX 1080 - I hadn't planned on water cooling when I bought the 1080, got lucky that EK makes a waterblock for this non-reference design.
Tubing - Primochill 1/2" PETG. Rigid tubing on my first build! I know lots of people say go soft tubing at first, but I'm really not a fan of the look and PETG looks relatively easy to work with. It will be time consuming and a learning process, I'm sure, but this is a hobby where the journey is just as important as the destination, right?
Fittings - Primochill Revolver compression fittings
Pump/Res: Here's the big part I'm still working on. I'm interested in the Photon 170/270 reservoirs with their pretty light setup, and I like cylindrical reservoirs better than the drive bay ones. It also comes in Pump/Reservoir combos with the D5. I'm not 100% sure I can make that fit, though. The Luxe lists the GPU clearance with the reservoir bracket installed as 338mm minus reservoir diameter. My GPU is 286mm and Amazon says 70mm diameter for the Photon. So it probably can't fit in the intended spot if that's in line with the GPU. If I decide I need to do a drive bay reservoir, I can save a few bucks and get one of the Alphacool 240 D5 kits.
I've ordered the case already, so will set up my current system inside and take a closer look before I order anything. Maybe someone familiar with the Luxe can shine some light (rimshot) on good reservoir locations.
Cosmetics: Leaning towards a bright green/black color theme: use UV green tubing and some UV LEDs for the case. Will start off with just distilled water and colored tubing, I think, but I've pondered UV dye for the fluid. However, I will wait and see how the setup looks before I do something like that. Between UV tubing and UV + RGB LEDs I think I'll be covered on coloring. Alternatively, I could go for "modular color" using clear tubing and various dyes to swap out colors as I see fit. The black case/MB makes a nice neutral starting point and I can just click a button in the Aura software to swap case light coloring to match new dyes.
Buuuut I'm a bit wary of using dyes on my first watercooling build. There are so many mixed opinions out there on whether it's fine or it's a gunk nightmare doomed to cause a catastrophic pump failure.
I also plan to decorate the case a bit. The empty left-side panel needs some love, and I'm going to put this logo on the side, which XCOM fans will recognize:
Roughly: "Warrior in the machine." Will tint it to match the (probably green) color scheme. Likely will just get a vinyl decal printed for it, can always remove that later if I decide I hate it, while spray paint is more involved. Maybe a little "Exadeuce" signature decal somewhere also, so people will think this is some kind of professional art piece, right? If anyone has some novel alien-themed decorating ideas, I'm all ears. I would love to make the logo glow, like with a cutout backlit with LEDs on the side/front panel... but one step at a time. I don't think I'm up to the task of carving up a case and having it look good.
So, it's obvious I'm willing to go all-out for this build. I'm sure it will be a long process. Any advice/pointers/suggestions are very welcome.
