Building a load balance box
Softgod
Disabled
OK, here is what I have going on. I have Comcast PRO service that is 4mb down and 384k up. Now that Comcast has upped everyone in my areas service to this speed I want to have two cable modems. It will actually save me like 4 dollars a month doing this anyhow and I will get more bandwith. Also, I am now working with a group of guys that are running a 350 person LAN and we have 5 cable modems for this event.
I need to make a load balance box for this. There are several available but this one comes to mind:
http://www.xincom.com
Now I want to have 5 pci 10/100 cards in a Pentium 3 500 system with 512 ram. This can be done on either Windows NT-2003 or on Linux. Just tell me how.
su root
Senior Member, --, I teach people how to read your
Ontario, Canada
You would need a 6th network card, for the LAN ;)
A dual-wan router is the easy way to do it, but I would choose linux.
A place to start would be something like this:
http://www.inlab.de/balance.html
But I've never used it..
Also-- your ISP may not like you plugging 5 modems into one house.. you may take over a good chunk of the bandwidth for your neighborhood (if the other 4 modems aren't from your neighborhood)
S
Softgod
Disabled
Actually, for the LAN they are going to provide them if I can figure out how to make the box. COmcast is on of our sponcers.
Fronic
I actually have the Xincom DPG502 and I love it. Comcast hasn't upped the connection speed to 3 megs here unless you pay 100. I end up paying around 75 after discounts.
Anyway, about the box; good wealth of features, very good stealth firewall and load balancing works perfect. On newsgroups I regularly get 3.5 mbps downloads (works out to about 440kb/s).
I think I'm going to post a review in this forum since so many people have been wondering about it.
Fronic
XWRed1 said:
Just round-robin interleaving of connections might break some things that establish multiple connections.
OpenBSD's PF can load balance nat like what you'd want:
http://www.openbsd.org/faq/pf/pools.html
That seems like it only does Round Robin. The Xincom does session based where you are able to download a file over 2 connections as long as you split it up.
S
Softgod
Disabled
It is mainly for the 150 people that need to do that Steam thing for Counter Strike. But they will not all need that at the same time either.
XWRed1
Senior Member
The round robin should end up doing what you want over time. I suppose in the short run, it might end up with two big connections on the same modem because it puts a simple http connection on the other.
Round-robin should work ok for what Softgod wants though. And OpenBSD should be alot more controllable than an embedded appliance.
