- Jan 5, 2004
- Indiana, US
I am trying to build a new rig and as I look through newegg, I add up prices and #'s. But it doesn't tell you how these things actually perform in the real world. I haven't really built a rig and followed the market since the radeon 9800 Pro's were hot **** So I have a basic knowledge of the new things out, such as the quad core's, SLI, crossfire, PhysX and what-not. But what I am trying to do is get some suggestions and reccommendations on whats worth getting and whats not.
Overall I am looking for a high/higher end gaming rig as cheap as possible, basically not top of the line but right under it.
Here is what I have looked at so far and my comments for each.
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
Ok, no one has said anything about this, still assuming a good decision for the setup
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
I hope to have some upgradability for maybe dual video cards or dual GPU's for some of the newer stuff coming out later. Also will having only one +12v be an issue? i noticed the 650w has 3 and the 1000w has 2.
ASUS P5Q-E LGA 775 Intel P45 ATX Intel Motherboard - Retail
I am hoping they make a 1600 mhz fsb processor I can afford to put in this thing.
Intel Core 2 Duo E8600 Wolfdale 3.33GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor - Retail
Went with the E8600 to take advantage of E0 revision.
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory - Retail
Ok so now if I am figuring this up right, Processor 1333/4=333.25 and memory 1000/2=500 so I should have tons of overhead with my processor vs ram.
SAPPHIRE 100259-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
This version of the 4870 that sapphire makes is supposed to run quiter and cool, not to mention I think the appearance of the card looks better. I think there will most likely be no performance difference.
Western Digital VelociRaptor WD1500HLFS 150GB 10000 RPM 16MB Cache SATA 3.0Gb/s Hard Drive (bare drive) - OEM
Decided to go with the 150g to cut costs. shouldnt "need" more than that.
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler - Retail + XIGMATEK ACK-I7751 Retention Bracket - Retail
Looks like a good deal
Acer P243WAid Black-Silver 24" 2ms(GTG) HDMI Widescreen LCD Monitor with HDCP Support 400 cd/m2 3000:1 ACM - Retail
24 inches 1920x1200 I am sure this will be a lovely monitor assuming the pixels aren't DOA and none of them burn out.. Are they making better LCD's these days? Or would I just be better off spending less money in case it does do something dumb on me like that. It is also the most expensive item on my list right now too
Down to a Total price of $1564.90
I know this is a tall order to comment on, but any knowledge is appreciated, thanks for the input I will keep updating as we go along!
