Building a new rig.
Pie-rate
Mmk, I'm going to build a brand new rig in a month or so, and I'd like suggestions.
Budget: $2100
Pretty much anything goes, except it absolutely must have a good nVidia GPU.
Totally willing to overclock.
Edit: Also, will the vapochill that's being sold in the below link work with the more recent CPUs (AMD socket AM2, for example?) Will I be able to afford it with my budget?
http://www.ocforums.com/showthread.php?t=490983
I'm kind of loathe to link it here because someone will buy it while I'm still thinking about it because of my free advertising :(
Budget: $2100
You'll want to look at Core 2 duo's....the performance is much higher than AMD's current offerings.
I think you could fit that Vapo in your budget. You might cut it close if you want to get an Nvidia 8800 GTX (Or GTS if budget requires)
But I think you could definitely build a nice rig for the price.
You might take a look at this thread:
http://www.ocforums.com/showthread.php?t=493863
A lot of ppl have given their recommendations for a $1500 system. Since you'll be using over $500 of that $2100 for the Vapo, you will probably be looking at a similar setup to what's being talked about in that thread.
EDIT: I'd say try to spring for the 8800GTX if you can, since you'll have all that power from a frozen Core 2 Duo CPU, you can use the extra muscle in the GTX
