- Feb 27, 2002
- Nashville, TN
building a plexi case for watercooling - Need your opinions and ideas.
I'm currently designing my case that I'm going to build for watercooling. Need some thoughts and opinions on a few issues.
1) How to determine where to cut the holes for the I/O ports and PCI cards. I was thinking that I could just measure the distance from the motherboard tray to the PCI card rack from a normal case and just go with those measurements. Ditto for the I/O ports. Just cut out one big hole and use the metal cover that comes with most motherboards to cover that area.
2) Motherboard mounting holes. I hope to upgrade my motherboard, so being able to do so is imperative. I know a lot of cases have many spots for standoffs. Is there any particular set of holes that are used by basically all mainboards so that I can just put the standoffs there?
3) PCI cards. What's the best way to be able to mount those? I bought an old junk case for $5 from a local shop to use for parts. I was thinking about cutting the PCI bracket off of that case and mounting it to the one I'm building. I believe it's just held on with rivets that I could drill out. It may not look quite as good, but I think the metal would be more secure for insert/removing PCI cards without worrying about stripping the acrylic.
4) Mounting the water cooling. I would like to build a separate chamber underneath the system in which to mount my reservoir and pump (res would also be built out of plexi). Not sure what's going to be the best way to do that and still be able to get access to the pump, etc if I need to. Also along this vein, would you use the pump inline or submerged in the reservoir.
5) Mounting the drives. I'm thinking about having all the drives flush against the right hand side of the case. I could run the screws through the right and into the drives from that side, though I would have to find somewhere to get longer screws to account for the extra thickness of the plastic. For the left hand side I would have something coming from the top shaped like this.
That would give me room for two 5 1/4" and two 3 1/2" devices. I don't anticipate having need for more than that, but should I maybe include room for one more of each just in case?
6) Last question (for now), Acrylic glue or screws? I'm leaning towards screws, based on the theory that if one panel gets damaged, I can always unscrew it to replace it. My concerns there are if the panels (will most likely go with 1/4" for strength) wil be thick enough to hold the screws. I could always go with corner brackets if that's the case, though they don't look as good.
Any ideas or thoughts are appreciated. Looks are highly important for me in this and I don't want to do a half-a$$ job with it.
Code:
| |__
| |____
