- Jul 19, 2011
Dear OC forums. I am a new member and am new to the gaming world. My friend told me to ask this forum because he is a member as well. I am thinking of building my first computer and i want it to be something that will last a long time. I have compiled a list of parts and would like the nice people on the forum to help me out since it is my first build. I do have some knowledge on computers and i can take one apart and put it back together confidently but this will be my first time working with expensive parts. Here is the list of components i am thinking of buying. Any input would be helpful but mostly telling me if this will work or if the build will be a complete disaster. I want this computer to run minecraft on extreme full settings with no lag at all (I know this sounds stupid but my friends $700 pc cant run minecraft smoothly on full settings). I also want it to be able to play battlefield 3 and MW2.
case-
COOLER MASTER Elite RC-310-BWN1-GP Black Steel / Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119203
processor+motherboard combo-
MSI 890GXM-G65 AM3 AMD 890GX SATA 6Gb/s USB 3.0 HDMI Micro ATX AMD Motherboard+AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.679660
video card-
HIS H685F1GD Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161348
power supply-
CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
hard drive-
Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
extra case fan-
Rosewill RFX-120BL 120mm 2 Ball Bearing Blue LED Case Fan with Fan Controller Set
http://www.newegg.com/Product/Product.aspx?Item=N82E16835200028
DVD burner-
LITE-ON DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model iHAS124-04 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
OS-
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
All added up with shipping and handling, this computer is $757.33
I know i am asking a lot for you to read my entire entry to help a newcomer but i would like to see what this forum could do. Any help would be very much appreciated.
Thanks
Josh
case-
video card-
power supply-
hard drive-
extra case fan-
DVD burner-
OS-
Thanks
Josh
