Building new htpc
chaos
INDY
What do you guys think of this case??? http://www.newegg.com/Product/Product.aspx?Item=N82E16811163158
I plan on putting the following itms in it.(If I decide to get it)
Mobo- http://www.newegg.com/Product/Product.aspx?Item=N82E16813135241
cpu-haven't decided yet-hoping my Fry's will have a great mobo/cpu combo for sale again
ram- at least 2 gb
Optical drive-LG Bluray/hd-dvd combo(got alot of hd-dvd movies)
would like to put 2 harddrives in it
Videocard-http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170406258284&ssPageName=STRK:MEWAX:IT
Wicked Klown
Hard *** Southern Boy Senior
Sheboygan, Wisconsin
Nice looking case. It's a little cramped for my taste but thats cause I like big cases. I'm hoping your going to use the LG drive you already have as they stopped making it. For the HDDs I would use two 5400rpm green drives to help cut down on heat in the case.
chaos
chaos
INDY
should I get 1 smaller drive and 1 bigger drive or just a big drive and make 2 partitions? was gonna get like a 250-320gb and also a 500gb, but then I just checked newegg and they have a 750gb WD green for $60.00
Wicked Klown
With the first case you have room for three 120mm fans, which means less noise. With the second one you have alittle more room a spot two 80mm fans and two 60mm fans. Trying to find a quiet 60mm would be hard. The two side 120mm fans plus the intake one should move enough air to keep things cool yet quiet.
