Okay, I'm considering (i.e. possibly) building a new computer, however I haven't been following the new technology much, so I could use a bit of advice. What do you think of the spec so far (haven't chosen on a case yet)?
1 x ASUS Crosshair SKT AM2 nForce 590 (£140)
1 x AMD Athlon 64 X2 4200+ 2.2 GHz Socket AM2 L2 1 MB (£112) 2 x OCZ 1GB DDR2-533 PC2-4200 Value Series (£130)
1 x Connect 3D X1900XT 256MB GDDR3 AVIVO TV Out Dual DVI PCI-E (£152)
1 x Hitachi 250GB T7K500 HDT725025VLA380 SATAII 7200rpm 8MB Cache (£47)
1 xWindows XP Home with Vista upgrade coupon (£57)
Also, I've got several questions for you guys:
1. Is the RAM okay? I know the AM2 processors run on a 200Mhz FSB, so is getting 533Mhz memory way too fast?
2. Which is better, the X1900XT or the Nvidia equivalent ? I know directx10 has come in the shape of the 8800 series, so hence why I'm only buying a mid-range directx 9 card - it'd be pointles to get a top-of-the-range one lol.
3. Speaking of directx 10, now that windows vista, should I spend the extra £100 ($190) or more and get Vista, or just buy XP Home with an upgrade coupon (meaning I can upgrade to vista for an extra £20 for the basic, or £40 for premium vista)?
4. Finally, what's a good AM2 heatsink? I want to do quite a lot of overclocking since I'm buying a premium motherboard, so I don't want heat to be a significant problem.
Thanks a lot
Thanks a lot
