- Sep 21, 2005
Ok, so as the title says I'm looking to build a 6400 or 6600 system, and I'm looking for some advice for some hardware choices. Been out of the loop for a bit and I'm jumping into a new architecture so I could use some help.
First of all, if I can afford the 6600 without a problem, is there any benefit to going 6400? Reason I ask is because I know that back in the 478 socket days going 3.0 or 3.2 ghz p4 wasn't necessarily better because if you bought a 2.4 you could overclock it like a madman, so I'm wondering if this is a similar situation. If the 6600 is a strong enough performer I'll just stick with that.
Secondly, I'm trying to figure out what motherboard to seat this in. The last system I built was a 478 socket p4, and I used the ABIT AC7-Max3 board, so I've been partial to ABIT. However I have no qualms going to Asus if there's a definitive difference/improvement. Figuring on money is no issue, what's the best board to seat this puppy in.
Last question would involve ram. Not sure how much I wanna stick in it yet but again price won't be much of a problem when I get this system built. Any suggestions?
I do plan on overclocking the rig so I'll need some headroom for ram I'm sure. I'd also like to go SLI on the mobo but I'm sure that won't be much of an issue if i'm going high end, regardless of what brand I side with.
Thanks for any help in advance.
Lastly, RAM.
Lastly, RAM.
