I'm building a newer system, I'm not a gamer, but I do a lot of research so often have a pile of browser windows minimized with Torrent client running, music playing and maybe a video or clip needing to be run with the system up 24/7 on a UPS. I'm currently running Win7 with no plan to upgrade the OS. Want something not top of the line, but upgradable as for CPU as newer comes out and current prices go down. Have gathered some ideas, but I'm behind the times on current builds, so here is my list. Would you take a look and tell me what you think please?
MB : GIGABYTE GA-H97-HD3 LGA 1150 Intel H97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Model #:GA-H97-HD3 $97.00 --- newegg
cpu: $199.99 ----- Intel Core i5-4590 Processor - Quad Core, 6MB Smart Cache, 3.3GHz, LGA-1150 Socket -
BX80646I54590 tigerdirect
CPU Fan/heatsink $27.99 ----- SilverStone Argon AR02 CPU Cooler - 92mm PWM Fan, 3 Ø6mm Copper
Heat-Pipes, Aluminum Fins, Hypro Bearing, 1200~2800RPM with PWM Speed, 56CFM Air Flow, 16-24dBA Noise -
AR02 Item#: KIV-101751206 | Model#: RL-AR02 Tigerdirect
Crucial Ballistix Sport 32GB Kit (8GBx4) DDR3 1600 (PC3-12800) 240-pin UDIMM BLS4KIT8G3D1609DS1S00 /
BLS4CP8G3D1609DS1S00 -------- $169.99 Amazon
Two Seagate 2TB Desktop HDD SATA 6Gb/s 64MB Cache 3.5-Inch Internal Bare Drive (ST2000DM001)
$72.99 ea ----- Amazon
Lite-On Super AllWrite IHAS124-04-KIT 24X DVD+/-RW Dual Layer Burner + Nero 12 Essentials Burning
Software + Sata Cable Kit $23.99 Amazon
Still need a PS, got an ATX case already. Atempting to stay under $600.00-US, like the MB because of the
# of SATA and USB 3.0 sockets and ability to replace Video and Nic if onboard die.
Any comments or better hardware/deals? Thanks for feedback.
