- Dec 20, 2000
- Pensacola, Florida USA
I'll post pics later but tell me what you think.....
I took an OEM processor heat sink and cut all but the outside "fins" off....then covered the open 3 sides with 1/8" alum plates. Put 2 nipples on that box. (also had a little due-hicky (that's southern) to attach it to the same places my OEM heat sink attached to.
I bought a Transmission cooler and an electrical box (from someone else's idea on the main page) built for underground work to store around 3 quarts of water.
2 8" fans fit perfectly over the "radiator" and a 75 gph (max.....it's variable) fishtank pump will power the thing.
I have a atx full tower case that has a removeable top so I could mount the radiator in it and have adaquate room for ventilation for it.
The entire system fits cleverly in my case and is completely sealed. I intend to mix 1/2 antifreez and 1/2 water to the system for lubrication and anti corrosive material.
Sound good so far? Gawd....I decided to over clock "just a bit" 2 days ago and now I'm building a custom watercooling system today. See what you people have done to me?!?!?! =)
