Burning hot VIA chip
Any reason it would be hot to the touch?
I am running my 633 @ 712 I don't think that would be enough to heat it up too much I could see running it at say 980mhz. Maybe that is why my system is unstable at 980. Could that cause it to be unstable?
Wow I have never heard of the southbridge being burning hot its usually just slightly warm when you touch it.
Pull out the pci cards and see if its still hot.
If not then start putting them in one at a time and check the southbridge until you find what card is making it so hot.
Ive heard of this before but not much, make or put a small HSF on it to take care of the heat problem and you will be happier, thats if it's not a MB problem causing the heat issue which it may be.
AmbientFiction (Jul 22, 2001 03:49 p.m.):
My rule.. if its hot.. COOL IT :).. I'm willing to bet that its either the problem or part of it.. cool that baby down and mabye the other bridge as well.
GL,
-Trek
I heard somewhere that VIA southbridges run HOT. My intel southbridge runs very cool w/o a HSF. Maybe its a via thing. :)
Vantec has a chipset cooling bundle with a southbridge greenie included.
my 686b isnt even warm letalone hot enough to burn my finger sounds like mybe one of your peripherals is mybe overloading it or something
