Burnt out?
AcEmAsTr
Huntingdon UK
After all the trouble i've had (see General Hardware) i finally find the problem, Sorry about size, this comp hasnt got anything decent enough to change it. I have a 250w spare one, will this be sufficient to power my comp?
You will probably be at about the lowest you can go as far as power, if you can get it to run OK. If you can't boot, or start getting random reboots and shutdowns, you'll know that isn't enough.
if you can get it to run your comp then its good...
but i suggest you buy a new one as it will serve you better for the long run...
hope your board is alright though...
