My retail p4 hs broke over the weekend, so I figured it was finally time to buy a new hs and some fans so I can overclock. After reading through a bunch of articles and forums for the last few days, it seems like the Vantec Aeroflow with it's default TMD fan and 3 24-CFM Panaflo fans was a good choice. I'm planning on overclocking my 1.8a as far as I can get under 1.7v w/o having to go too high in dbs with air cooling (never bought fans, right now I just have the side intake and 2 exhaust fans on my chieftec case), so I'm not sure how loud in dbs will be too loud for me. I sleep with the computer in my room, but I'm a deep sleeper, so as long as it's not much louder then it is with just the case fans, I will be happy. Knowing how high I plan on ocing and the noise tolerance level, does this combo sound like a good idea? Will the 24 cfm panaflos be good enough for extra case fans? With them I will have 2 front intake, 1 side intake, and 2 exhaust (including the psu fan), plus the Aeroflow fan.
My main question though is this: I have a TH7-II mobo and my chieftec case, what connectors should I get with my Panaflos? It looks like the mobo has 2 3-pin connector slots left, so should I buy one 4-pin connector for one of the panaflos? Here is a link to the Panaflos i'm getting:
http://www.kdcomputers.com/eui/prime/profile/523/25/component.htm
It sounds like they come with 3 pin connectors, but I'm not a 100% sure. I'm assuming that if they come default with 3 pin connectors, that the site sells something to convert them to 4 pin connectors.
