First of all, Welcome to the forums.
That being said. I just purchased another XP1600+ to compliment the one I already had for a new dual system I was building. The new CPU is AGOIO stepping and as has been reported lately this CPU did have the additional L5 bridge cut, my original CPU does not have it cut.
Once installed on my Tyan 2460 motherboard the BIOS recognized both CPU's but would stall during POST. The boot toime was approaching 4 min. I did disable ECC check in the BIOS which helps speed up the POST but to no avail.
I removed the CPU and simply joined the third bridge as the original one was. I used rear window defogger repair fluid, I did not fill the pit first. This proccess is much easier than unlocking the L1 bridges on these CPU's, very similar to unlocking the original T-BIRDS.
I reinstalled the CPU and it's worked like a charm since.
I hope this helps.
Good Luck!
Here's a shot of both CPU's compare the L5 bridges;
