SOLVED Buying fans
J
jb
Guest
Where is a good place to buy Panflow fans or any fan for that matter I went to price watch but they have no listing for Panflows atleast . Dot com purchases or retail computer stores , basiclly anywhere I can get them fans for a good deal .
Another quick question I bought a case that came with two fans that only blow like 31cfm I want get the a fan that is stronger , faster and better in every possible way. I don't know how big my current fans are so making an online order now could be a big pain in the !$?.
I want to know if you measure them (like a t.v.) from corner to corner or just directly across the bottom ? I'm not conserned with the thickness of the fans only the perimeter.
Thanks ahead
hey man, i buy all my things usually at www.azzo.com, you can check out their links for fans HERE. also, fans are measured at their diameter, so measure across from the center, and you got the size...like 120mm, that happens to be the size of a cd, spiffy!!! hope that helped ;-)
Ya man that definitely helps now I know for sure without modding I can use any 80mm fans.
thanks again
dang peewee those are a hell of a lot better than mine, mine are 90 cfm sunon 120mm ultras at 44.5bda and i didn't get one already with chrome grill, hada buy it separate :(, and for 15 bucks too! ahh! thanks for that link, too bad i dont buy things online often at all..., heh...good thing there is always room for exception!!! :D
Light~Being (Jul 26, 2001 08:40 p.m.):
yeah they are like half price of anyone else i have seen.. not to mention they come with the metal grill....i got 2 of em and they are sweet....
bought 5 panaflos at b.g.micro for 7 bucks and i also bought that 12v 235cfm fan for 8 their too ( the things 52 decibles, makes a delta sound almost bearable). also try mpja.com and allelectronics.com
Generally, the larger the power consumption (or larger current (amp) rating at constant voltage) of a fan, the more powerful it is. Fan sizes are of the length of a side (they are square!) and the thickness of a fan. Thicker fans tend to displace more air than thin ones (just look at the 7000+ rpm Deltas or YS Techs). Most fans last at least 2 years. Branded ones tend to be quieter or lasts longer.
just so everybody knows that the "panaflows/panflows" are spelled panaflo. hope this helps with searching on pricewatch. whiskey u the only one to spell it right but i can't spell anyhow.
