Buying used stuff
The_Punisher29
Montreal
I don't know which to buy I can take one of these 2 kit.
-Gemini Spiral
-Eheim 1250
-Heater core painted black
-DD reservoir ( won't buy it )
(all 3/8'')
185$CDN + shipping from Toronto to Montreal
or
-D-Tek TC-4 Poly top w/ a small crack ( maybe going to need alu top)
-Danner Mag Drive 5
-Heater core
140$CDN no shipping
Both are used... Is there a risk in using it used...
:confused: :confused:
JFettig
Hey! I showered! Senior
MN
holy crap, the tc-4 one is a TON beter, a danner pump, much higher performance than eheim, tc-4, again, much higher performance than gemini spiral, heatercore(both of them ahve it) and the second system is 1/2" tubing, I would definately get the second one and a new top.
Jon
WejRepus
Redwood City, CA
definatly 2nd set-up...
only problem w/ used set-ups is you cannot be sure if it is leak-free...
you would definatly want to change the top in the tc-4
Holsum
In you raidz, Stealn your Purplez
Punisher i Third that....The second setup is better not to mention cheaper. Yes you can get a different top if it is cracked just email danny(at Dtek) and ask him if he will replace it for you.
Good luck!
TyRex
Indiana
The_Punisher29 said:
well the second setup will be easier to deal with since the seller is located in my city ! ;)
even more of a reason to take the 2nd one......that really is a good setup
Korndog
California
aww.. the gemini isn't that bad...
plus ehiem is a better pump
(sorry, gotta get some kind of argument here)
JFettig
MN
who says the eheim is a better pump?
Do you know how good danner pumps are? they are just as reliable, and have TONS more pressure and flow.
the second one is gonan be a ton better.
