BX133-RAID BIOS update
Rudy
I cannot seem to follow Abit's update guide. I prefer to get the expert's opinion before making a ton of mistake. Would the experts kindly help me identify which of the following BIOS files is apprpriate for my motherboard which is version BX133-RAID VI 033027571-258KE and BIOS ID 6A69KA1CC-SZ:
[ BX-133 RAID]
Filename: BERXK.EXE
Date: 01/04/2000
Support Celeron 800MHz(100) CPU.
Support Flash Menu.
HPT 370 RAID BIOS verson 1.0.3b1.
Filename: BERUK.EXE
Date: 09/05/2000
Supports to PIII 1GB CPU(133MHz FSB).
Filename: BERVI.EXE
Date: 12/21/2000
Supports Celeron 633Mhz(66)CPUs.
Adds "IdIe/Pipeline DRAM Leadoff " option to the BIOS (Under "Advanced chipset Features")
Adds "PCI latency timer" option to the BIOS (Under "PNP/PCI Configuration")
Resolves "PNP/PCI configuration" setting display error
Supports ABIT FlashMenu.
HPT370 RAID BIOS Version 1.0.3b1
Filename: BERUK.EXE
Date: 09/05/2000
Filename: BERTT.EXE
Date: 08/11/2000
Supports VIA Cyrix III CPU.
Filename: BERSZ.EXE
Date: 07/06/2000
First release.
Thanks guyz
I thought the latest BIOS update is the best one to get. Each update just enhances the previous one with new features for the board.
As my previous post didnt tell you which BIOS update to get, here it is. The one you list as 01/04/2000 has the wrong date. It should read 01/04/2001. The file BERXK.exe is the file you want. The date thing was ABIT's error on the BIOS update page.
chris (Mar 02, 2001 07:25 p.m.):
Thanks Chris, this confirms the message I got from my supplier.
