As of Sunday, my newer computer has been d/ling at 200ish kb/s instead of the typical 700 kb/s. Thinking it was my ISP, Charter Communications I didn't think much of it. However, my older computer that is on the same hub, was still able to d/l at 700kb/s.
I switched ports on the hub, yet I still recieved the same problem. I connected directly to the cable modem with my newer computer, same problem. I tried a shorter, different CAT5 cable, same problem. I release/renewed my IP numerous times. I have also uninstalled/reinstalled tcp/ip.
After doing these and still having no resolution I called tech support. They did what they could but we have determined that the problem is on my end, since my other computer is still d/ling at normal speeds.
Getting desperate, I deleted the partition on my harddrive and did a fresh install of Win2k Pro, and I STILL have the same problem. I also re-seated and relocated my network card.
The only possible explanation is the VIA drivers I downloaded sunday night. Could they have cause problems with my connection? How can I fix this?
Help is appreciated in advance.
System Specs:
Asus A7V33
AMD Athlon XP 1900+
256mb PC-2700 DDR Samsung
MSI G4 TI4400 300mhz/620mhz
If you need any other information, please let me know. I'm downloading (although slowly) the service pack updates as we speak.
System Specs:
Asus A7V33
AMD Athlon XP 1900+
