- Jan 4, 2001
- Northern VA
Hey, I've got a favor to ask. I'm working on a computer here that keeps corrupting the Win2k Registry, and I'm sure its a hardware problem. I've posted threads on this problem, and gotten away from software issues and looking at hardware issues.
Two things were suspect, the PSU and the RAM, a single 256mb stick of Crucial PC2100.
I switched off the Quick POST in the bios, which let the RAM go through it's slower check. The result was the ram being checked three times, each time it would just start the count over again.
This is making sense right? I'm talking about the count where it counts "256,xxx OK"...yeah it does that three times before continuing on.
Anyway, my experience is "That shouldn't happen"
So unless something has changed on the Epox boards, cycling three times through the memory check means the memory is probably defective.
So could you guys do me a favor? In your BIOS, under advanced, set the Quick Power on Self Test to [Disabled], reboot, and see if you RAM cycles just one time. That'll give me 100% assurance the RAM is acting up.
The closest thing I have here at work right now is an 8K7A, and no free DDR DIMMs I can test with without disrupting someone from working...
Thanks!
Mike
Thanks!
Mike
