- Mar 7, 2008
Basically I want to look at the IPC of Zen+ with and without SMT on, but I don't own such a CPU (yet). Any volunteers to help with that?
Let's just go for two benchmarks for now to keep it simple: Cinebench R15, and 3DPM. We all know CB15, but you might wonder what 3DPM is... it is something Ian Cutress of Anandtech wrote himself. If you wonder why I'm interested in that, it is because it shows massive increases comparing SMT on vs. off, higher than on Intel.
Ian linked to 3DPM at the twitter location below.
Because I'm interested in IPC, it is of most importance to know what clock the CPU is running at, so I'd suggest setting a fixed clock regardless of number of cores active. It doesn't have to be a high clock, only that it is fixed and stable. Run each bench at least 3 times, and let me know the best overall scores with and without SMT enabled. For CB15, only the multi-thread test is needed, not the single core one as by definition that wont use SMT. We know ram has a weak influence on CB15, but I guess it doesn't directly impact 3DPM other than the cache speed tie, so please also state ram speed/configuration as well as CPU model/clock.
Edit: anyone know what the all core turbo is for Ryzen 2000 series? Is there even one at all? It looks like the new boost feature over 1st gen means it is less predictable as it aims to optimise performance to the conditions available.
