Also, its pretty much useless (with AMD atleast) because it increases the ram bandwidth without increasing the CPU bandwitdh, so the extra doesnt get used. Basically it lets you run the ram at a different speed than the fsb.
Yeah, that's my major gripe I have with AMD, the memory bandwidth isn't what it could be.
If AMD could boost the fsb like Intel does, as well as get the clock speed up there too (while keeping the performance per mhz it's known for)..........well, Intel would be toast
Hehe, would've liked to have seen the new XP's have a fsb of 200 instead of 166
Course only one available board (Asus A7N8X) "could" officially support it right now, and JEDEC doesn't have official support for DDR400 (although this doesn't bother me I know it bothers some people)
There's nothing wrong with running it that way, using the mem divider to increase the memory bandwidth. The thing is that the cpu will only use the bandwidth as if it was DDR324, since that is the fsb.
so shouldn't you have the ratio at 1:1 at all times then since the CPU doesn't use the extra bandwith anyway and you are just OCing your memory unnecessarily?
