- Dec 20, 2001
What is the best pelt w/ HSF combo out there for the second rig in my sig. I also want to up the v-core to 1.75 and run the chip at 1.8 if possible.
Bender said:An 80 watt peltier with any good heatsink will do you just fine.
Actually, It would be fairly easy to use a 120 Watt pelt, even if the pelt is putting out 120 Watts. I don't know the exact wattage of a Cely, but let's say fifty for nice numbers. My alpha/Delta 80 gets a thermal resistance of .19(According to Radiate). So the 120 Watt pelt + the 50 Watt CPU puts a load of 17 Watts on the CPU, bringing the Hot side temp up to 32 above ambient, which is an acceptable level. I'm sure better results could be acheived with the Swifty.Bender said:Actually you might be able to get away with a 122 watt pelt since it will only be running around 90 watts if you have it on an ATX PSU.
There is someone here(I don't remember the name) that is using an 80 Watt on an XP 1600 with fairly good results. I wouldn't do it on anything above a 1600 though, that's really approaching the limit.NEVER
