Can anyone recommend a good cooled case?
i'd figure out what kind of case you want and then modify it with fans (i.e. cut your own holes). you can use some of these case mod sites for ideas. if you see a case you think you like, do a google search on it with the keyword review. it seemed every case i liked had reviews around.
here's some places to get you started for ideas...
www.3dcool.com
www.caseetc.com
www.pcmods.com
www.virtualhideout.net (seems to be down at the moment)
www.phamcomputer.com
www.designcomp.com
www.directron.com
you'll find lots of other ones.
