Can double up on fans?
amaesing
CA
Hi all, my air flow is okay, my temps are at: mobo:28-30, and cpu: 40-45. I wanted to know if I could put two fans or stack another fan on my Alpha 8045 to get my temps down? I have two 80mm panaflo's one intake and one exhaust. and a high cfm sunon blowing in on the alpha(tried both ways, and blowing in drops 2 degrees for me. Can I add another fan on top of that?
Let me know, thanks
nikhsub1
Unoriginal Macho Moderator
Los Angeles
You could try it and see but I recall reading somewhere that this works worse than 1 fan. I believe they "choke" each other.
A
amaesing
CA
Wow, didn't know that, k, i won't stack them. Instead should i get a better exhaust or intake fan? Both panaflo's have the same rate.
Yodums
Senior Member
Ottawa, Canada
Its one on top of another like right on top, the air current would start fighing and get no where, if their fairly far apart then its ok. You can make an air duct above the CPU Fan like that, just not close.
Iron Hawk
Groton, CT
Dont put them right next to each other, that wont work well. Instead make a duct in between them, if you have the space that is.
