- Apr 20, 2004
- JAX, Mississauna
Maybe first 970 MSI board in nearly a year...
I have noticed though that when I up my cpunb, either manually or via fsb, that sometimes my comp will boot up and windows looks funny. Like the task bar gets changed around from its normal look to some kinda weird chromed out thing and if I go into the net, the pages are slow to load and sometimes it stalls out. = CPU/NB handles the cpu to ram tranfers for one thing so if CPU/NB is too high or voltage low it could effect the ram and bad ram often gives bad video so raise the CPU/NB voltage to about 1.225 as AMD says it is good to 1.3 and is usually set by default on most boards to about 1.1 to 1.175.
I set my ram voltage manually in bios to 1.507 and that seemed to help. = I run my Gskil Ares (low profile for large heat sinks, at 1.525 since I put it in their slots. The fact raising voltage seemed to help wonky looking windows would indicate that you are having some issue at that location either CPU/NB speed/voltage or the ram just needed some more voltage.
1 - Should I mess with the cpunb voltage any = Already answered above.
2 - Where can I find what my default cpunb voltage is set at? I am having a hard time for some reason finding it in the bios. = Yours is really the first MSI 970 chipset board that I remember seeing in this forum section in nearly a year. We have seen a general trend to the later MSI AMD boards seeming not to be as good as they used to be so we have not really been suggesting them to users and the number of MSI 970 boards has been zero as I said. To date anyway so we have not seen any pictures posted of the bios to look for settings. Most of us are Asus or Gigabyte.
You might take some pictures of the page or two of bios where you set up overclocking voltages and stuff and attach to the forum and we can all look for CPU/NB stuffs with you.
Good luck and be well man.
RGone...ster.
RGone...ster.
