Hey all. I have a Asus P4B266-C and a 1.6a at 1.6 volts running at 2208. Not bad but I wanted to get higher. My fsb is running at 138 with a 1:1 ratio. Everytime I run Prime95 at anything higer then 138 I get hardware failure. What should I do? Should I increase the voltage? Would that help? I don't know what else to do. Or maybe this is the max this chip will do? If you guys can let me know I would appreciate it. Thanks.
