can i get some pics of water cooled rigs in some mid towers???
TomC
Southern California
Pentium 4 [email protected]
Case: 16.5"H x 6.75"W x 16.5" D
Pump: Iwaki MD-10
Block: homemade direct-jet (to IHS)
HeaterCore: cut down to fit
pokpok
heres mine
mycooldpc
were you wondering about pump and HC placement?
Edit
Case - i cant find a tape measurer or ruler right now but its the same thing as a chieftec dragon (mine is some knockoff called Aspire Turbogamer)
Pump - Hydor L30 i got this because it left some room for my ABS res
block - home made
Radiator - Dtek's heatercore w/ a 1" deep shroud + a 25mm (120mm) thickness fan. so its about 6"x6"x4"
lazyart
My rig:
Case: Antec (same dimensions as LANBoy) 16.5"x16.5"x8"
Pump: Maxi Jet 1200
Block: Danger Den Maze3 w/socket hold-down
Rad: 1966 Mustang HC
Res: R/C fuel tank
It currently differs slightly from this pic.. rad has been moved forward, the 120MM intake fan was removed to accomodate it. Twin 80mms are shrouded pulling air in.
