Mixman said:
I want to try an XP90C because I hear it the best in air cooling....even if it's a degree or two over the XP120 and I have some really good 120mm fans lying around that would be perfect. So, I want to know if I can use a 120mm fan with an XP90C ? Do I need a 92-120mm fan adaptor ? If not how will I mount it ? Oh, and would it give better cooling than a 92mm fan will give ?
I see in your sig that you already have a big Typhoon on one of your rigs and therefore know that it or an XP-120 would not fit on your DFI Lan Party.
While you could try to use an 120 to 92mm adapter and try to attach it straight to an XP-90C it would not work very well and I personally would not trust it. Since you would have to make your own wire clips or wire tie a 120mm fan onto the heatsink in order to hold it in place furthermore if you did not use an adapter a good portion of the fan would be hanging over the sides of the heatsink and that would be where the majority of the air flow would go and not down through the heatsink where you need it to be. Or worse yet it would create so much back pressure due to the adapter as to defeat the purpose.
Now there is a way to do it and do it right so that you would get the most airflow where you need it and still use a 120mm fan.
Here is how you do it.
Take a 92 X 38 mm fan and gut it out. Keeping the shroud of the fan as a spacer.(You could use a 25mm fan but I recommend a 38mm fan due to the increased width to allow better air flow with less turbulence)
Next using a 92 to 120mm adapter. screw the adapter to the top of the spacer and the 120mm fan of your choice to the adapter. Now what you have is a nice spacer that will not only eliminate the dead spot from the hub of your fan and give you better cooling but in addition since the blades now spin further away from the fins of the heatsink you get less air turbulence and therefore less noise as well.
Since you use the existing clips that came with the heatsink to mount the 92mm fan shroud onto the heatsink you need to make no changes to your heatsink either.
Here is a pic of something similar I did with my XP-120mm however notice that I did not need to use a 92mm Fan shroud or an adapter since I was able to use 120mm fans.
I have been running this setup for well over a year and I have had no problems at all. So yes the clips will hold provided that you attach them correctly of course.
I hope this helps.
