Can I use passive cooling on a P233
DaWiper
Image Compare Man
Norway
I'm thinking of putting together a gateway/firewall of a old pentium 233. It has to be quiet cuz it will be on 24/7.
If I get a large heatsink and no fan, will it be enough to cool the cpu?
repo man11
Yes. I had an old Dell with a P200 that came from the factory with a large heatsink with no fan. It worked fine.
As listed at Sandpile.org, typical power for the P55 is less than 10 watts. Far less than any modern CPU.
eobard
Give me a break Senior
You might want to look into underclocking and undervolting it if it's only going to serve as a firewall, my firewall is a P1 133 and its fine for that task.
Glaze132
Las Vegas, NV
I have a K6 300MHz that was sold passively cooled and still works fine to this day and the psu fan was the only fan in the entire system and that thing isn't even loud either. But I don't use that machine anymore, it is just to slow. I'm betting you could do the same with a cheap hs for you 233MHz cpu.
sandman001
Just Freeze It
My P3 500 is passive, straight from gateway this way.
Runs a bit warm, but then I added a case fan it cooled it back down.
DaWiper
DaWiper
Image Compare Man
Norway
Ok, maybe I'll try with a nice big heatsink and a thermal probe... Think it will work just fine. If I just coul figure out how to kill the psufan noise...
eobard
I use diodes to lower the voltage on my fans. A 1N4001 diode will shave .7v off and a 1N4002 (which I use because I can't get the 4001's locally) will shave .3v off of your fan's 12v. I run 5 in series and lower the voltage of my heater core's fan to 10.5v and it's a lot quieter. You can see in the pic below what I've done.
#1 is where the mini molex (for floppy drives) connects to the board
#2 is the jumper that lets me choose between full voltage or full voltage -1.5v
#3 is the output for the fan
#4 is a jumper for the molex's 5v line just incase I need it for something else
It'd be a lot simpler to make a circuit like that that doesn't have as many diodes and doesn't need the jumper part. Just splice into the live feed for the PSU's fan and solder inline two or three diodes, you don't even need a circuit board for that. Make sure you heatshrink the whole deal though, you do not want a short in your PSU!
sandman001
Just Freeze It
That seem slike kidn of a pain to do that, While it may be more expensive, I'd just get a fan controller.
cmonkey
You can run a p233 with no fan. I had a p233 that had a tiny heatsink with a 40 mm fan on it. The fan died without me knowing about it a long time ago. It hasn't overheated, and it has remained rock-stable. Earlier this year, it had an uptime of 6 months. (it went off during that big blackout). So, there should be no problems at all as long as there is some sort of heatsink on the thing.
Startech
DFW
Get a nice big heatsink and go for it. If it shortens the life of the CPU, so what? Get another one for nothing. Not like if it was a 2.4c M0! :p
Cyberwiz01
hunting wolverines
that cooler should be more than enough, like it says above, a Pentium 1 won't put out very much heat. The northbridge on most modern boards probably puts out about as much heat as an old pentium.
flixotide
Denmark
I've had several passive cooled P1-233. The Slot-1 P2-233 however was harder to keep cool.
So before I say, YES you can, I would need confirmation that you are talking about the old Pentium 1 - 233.
Is it with or without the MMX? The MMX series grow warmer though. But it should not be an issue.
Cheers, Flix
Korndog
California
my friend has a huge copper passive heatsink on his althon tbird 1.3ghz with on case fan blowing air out.
run about 55c and he doesn't mind
if it can be done with a 70+watt CPU, then it can be done with a ~25watt cpu like urs, lol
Korndog
California
ok i'm a moron, my 450mhz data/pinter server computer has a stock passive heatsink on it, only psu fan, stock from toshiba, been running for years like that so if it can do it a p233 can fo sho
L337 M33P
TEH INTERNETS
The 1N400* series are all bog-standard silicon rectifiers - the number after the 400 bit is just the voltage rating. A silicon PN junction always drops 0.7V, so that ain't right. 1N4002s should also have a forward voltage drop of 0.7v. The only types that have drops lower than this are Epitaxial or Schottky barrier diodes, and even then they are 0.5v.
Good idea to use diodes though...
