- Jul 30, 2001
- Chesterfield Uk
While I'm not doubting your soldering skills I think what you are both missing is once that sink is bent back down so the ram chip is where it would need to be for re-soldering, you won't be able to solder the pins because the sink will be covering them especially where the caps are.
Also if you read through my suggestion it's a little bit more than just epoxing the ram chip and hoping it works. The first epoxying part still allows you to solder it if it didn't work so you are no worse off and looking at the pic all the pins appear to line up, I'd put money on my method working.
I might be wrong but I got the impression the ram chip is only broken away from one side, the other side acting as a hinge, so your original idea of bending one end down to solder it wont work either.
If you had another new ram chip I guess you could do it easily but with the sink on if it overhangs the chip more than 1mm you wont be able to imo.
Hi Sam, how's life?
Hi Sam, how's life?
