Can Not Install Radeon 8500 on BX Board
Kaiser_Sose
I follwed this guide to not only uninstall drivers but install my new 8500 128 MB at the same time.
After Step 5 is when I took out my Radeon 32 DDR [7200] and installed the 8500.
After I reooted I installed 9009 drivers by pointing windows to the folder where it is extracted ... the .inf installed
After I installed the drivers I rebooted but its not working, it says ..... Your display adapter conflicts with another device in your computer, To correct the problem, click OK, ....
In the device manager under Display Properties it does say Radeon 8500/Radeom 8500 LE and under the resouce tab it says ..... Memory Range 00000000 - 0FFFFFFF used by:
System board extension for PnP BIOS
Promise Technology Inc. Ultra66 IDE Controller
Memory Range 00000000 - 0000FFFF used by:
Input/Output Range 0000 - 00FF used by:
Programmable interrupt controller
Numeric data processor
Memory Range 00000000 - 0001FFFF used by:
I have tried several times now removing the device and starting over again
What should I do
P 3 1 GHZ
MSI Bx Master
Win 98 SE
K
Kaiser_Sose
It has to be something with my BX board ... I need to fix this because that my gaming machine
As I said before I put back my 32 DDR and thats fine. Then I tried an experiment ..... I just shut down took out the 32 DDR and put in thw Radeon 8500 128 MB .... rebooted and I get the same error
Your display adapter conflicts with another device in your computer, To correct the problem, click OK, to view the properties of the device
When I click OK ...
The device can not find an Input / Output range [I / O] resources to use [code 12]
I shut down and put back my 32 DDR and everything is fine ok
I then installed the 8500 in my ECS K7S5A which previously has a 7000 .... it detected it fine and everything is OK.
I need to get this 8500 to work with the BX master in Win 98 SE because that is the machine with all my games .... the other one is my server
tainice
Carbondale, IL
never own a ATI product, but i would suggest u uninstall the card again, and this time, make sure u did not get lazy and try to combine two steps into one or skip any reboot. also post this thread at "vid card section," u will get more attention as well better advices. cheers
