CalebtheImpaler
- Jan 25, 2017
So, I can overclock my FX-6300 in AMD Overdrive. Left the base clock as is and increased the multiplier so my frequency ended up being 4.5 GHz. Then upped the CPU voltage accordingly to 1.4125 volts. Then confirmed my clock was set using CPU-Z and Speccy. Ran Prime95 for a few hours, no errors, temp maxes out around 58 degrees Celsius.
Now, I can't do the same overclock when trying to set it through BIOS. If I remember correctly, I can get the frequency up to 4.3/4.2 Ghz. I can set the voltage to 1.375 volts or so, but anything after that and the computer fails to POST (CMOS reset, everything's fine). Why?
I suppose I could be missing an obvious setting in the BIOS. Anyways, here's my motherboard MSI 760GM-P34(FX) (I know it's bad, new to this). Thanks for looking!
