Hi
Have a strange sporadic power related issue after reinstalling a faulty water cooler. First a very brief background.
Had a total WC failure whereby a coolant hose came loose and drained entirely on to the base of my case and floor. My machine ran for several hours before shutting down by itself. AFAIK no coolant splashed on to my mobo (Asus X99 A-2)
After reinstalling the new WC replacement at first was getting no power even after testing my PSU by applying a 24 pin jumper. So assumed my PSU was at fault. Someone suggested I remove the CMOS battery. I did so, carefully wiping with a lint free cloth and a tiny bit of isopropyl alcohol. Replaced battery, switched my PSU on, and it worked again!
So now a few hours and several reboots later, even ran a stress test with RealBench, which it didn't quite pass, got a Windows blue screen after 10 minutes but I don't think that in itself indicates anything serious. I get a blue screen about once every 2 weeks on my Windows laptop!
So being more confident now I went into BIOS and used the Asus 'EzTuning' option to set a "Performance Mode" overclock.
Tried to reboot and..NOTHING.
What kind of freaks me out though is I was getting NO power to my mobo as well....no glowing LED's!
So again I removed power cord entirely, removed and reinserted the CMOS battery and I was able to get my PSU working again.
I assume doing so also resets all BIOS settings?
Anyways I am left confused as to why I am having these power issues.
Why would removing, replacing the CMOS battery have any impact on the PSU? Especially if my main 24pin power cord is disconnected from the mobo?
And should any sort of overclocking impact my PSU in this way?
Can anyone explain what is happening? This is my first build, only a few months old.
