- Jun 8, 2002
I personally would choose Debian, because its package management system makes it easier to mantain and its a bit more flexible (IMO) when it comes to which packages to install. The default install is 50 megs, so you wouldn't have a disk space issue.
The two distros are aimed at mostly a similar audience, so either is well suited for your needs. If I was you, and I didn't have any prior experience with either of them, I'd give them both a try. Assuming this isn't a project that needs to be up ASAP, its good to play around with different distros to get a feel for them.
