At 1.85 volts it would put out 75.7 watts at 1300 mhz and 80.9 watts at 1400 mhz.AcidBath (Apr 17, 2001 07:16 p.m.):
how many watts would a k7 1.2/200 oced to about 1.3-1.4 put out??
180 watts of cooling power needed.AcidBath (Apr 17, 2001 07:47 p.m.):
thx man. 1 more question if i have a cpu running at 80watts and have a 100watt peltier would i have to cool 100watts or 180watts??
AcidBath (Apr 17, 2001 07:56 p.m.):
Huh so it will only be 100watts for the peltier? im confused hey look i didn't know i got my first startearing up...
I got one that was about equal to what my CPU puts out and it worked out great. I didnt want to go too far below ambient because of condensation. I put an 85 watt leuftkens on there and it worked out perfect. I had my 1200 running at 1400 with plenty of room to spare (till I crushed it). This 800 just sucks and wont go any higher no matter what I do.kat (Apr 17, 2001 07:50 p.m.):
i believe that you should come as close as you can to double your cpu out put ;D
100 watt pelt + 80 watt CPU = 180 watts heat generated. The pelt puts out 100 watts by itself and if you add an 80 watt load, there will be 180 watts of heat coming off that puppy.AcidBath (Apr 17, 2001 07:56 p.m.):
TT120 (Apr 17, 2001 08:04 p.m.):
I dont think a normal HSF could handle anything over about a 50 watt pelt or so. 50 watts + say 70 for the CPU is about on the outside limit of an air cooled setup.kat (Apr 17, 2001 08:06 p.m.):
i put an 85 watt pelt on a 1ghz tbird @ 1246 (82 watts) hooked to a hedgehog and my temps went up i should have been using a 170 watt pelt and a better hsf ;D
TT120 (Apr 17, 2001 08:14 p.m.):
