Can`t enter bios!!
Swede
Hello everybody! There is a thing that scares the sh*t outta me!!! I can`t enter bios! (I have no password)
Windows works normally..
There is only a black screen when I attempt to enter it!
I`ve tested one more monitor but the problem remains!
I have no idea how the problem started!
I`ve flashed bios but it worked fine after the flash!
Can it be my graphic card?
Motherboard: MSI K7T 266 Pro
GeForce2 Pro 64Mb DDR..
please help im nervous!!
have you been able to get into bios since the flash , my old bios before I flased it took two keys to enter ,you had to hit tab first then hit delete , since I flashed it you only have to hit delete , you may want to read up on the bios to see, hope this helps ,wildone
yes i had no problem to enter bios after i`ve flashed it...
It might be the Via 4in1 drivers.... I use the latest version 4.32
Could be wrong, but it sounds like a video display problem. Have you tried installing an old videocard just to see if you can get in?
maybe there is a toggle to change the display colors in the bios....
I have cleared cmos= did`nt work
Tried another screen =did`nt work
Tried another graphics card = worked! And that was a 5 year old 4Mb Pci card!
have the 4,32 Via 4in1 drivers and
Detonator 12,10
Conclusion?
Change graphic card! YES!
It lasted for two weeks! All brand new!
Electical components either work a long time or fry quickly...obviously you got one of the latter with that card.
