...I'm sure it can, but I wonder how much and with what effort ?
I have a large heater core mounted in a sealed enclosure, which also houses about a 3/4 gallon reservoir, with a pair of 120mm panaflos (7V) pulling air through the whole thing. It is connected to my HTPC by about 10' (20' total -10' supply, 10' return) of hard copper piping (5/8") which is mounted on a baseboard. It is all in an equipment room which is climate controlled.
Anyway, the "looks" of the system is unimportant, as its in an largish A/V equipment room, and can't be seen or heard.
Here is the deal:
Under 12 hour plus heavy load (water heated to the max - no more temp rise) I have about a 25c ambient, 36c water temp, and a 47c load.
This is on a intel 920 dual core 2.8 @ 4.2, 1.425v, Apogee water block, danner mag 5 pump - all 1/2 ".
I would like to replace the 10' sections of pipe connecting the PC with the WC rig with some sort of copper-finned tubing, or a passive radiator like the Innovatek Ultra unit, but I don't know how much more improvement I could expect.
Forget about the waterblock / CPU improvement for now - how much closer to ambient is reasonable to expect with a large passive radiator added to the loop (or another active / fan radiator which is not restrictive) ?
About 11-12c is the difference between ambient and water temp at full load, time-stabilized. How much room for improvement (reasonably) is there ?
Thanks for any help.
- Chris
Here is the deal:
- Chris
