Having applied AS to my Glaciator twice using the old 'finger' technique I then discovered that AS has instructions on their web site. So I applied it again carefully following all the steps including the cleaning and heatsink 'tinting' (something I never even thought of before). Everything went well until I got to the step of trying to apply a THIN/EVEN layer of AS on the CPU core? Is this really possible? I tried for about an hour and I couldn't get even close to the smooth appearance in the photo in the instructions. The razor seems to drag the AS resulting in thin spots or if I use less pressure there are bumps because I couldn't hold the razor perfectly level and flat with just the right amount of pressure ... I eventually just gave up and accepted a not-so-smoot layer of AS covering the core. I guess I did something right because my load temps appear to be down 1-2C. I think it was the 'tinting' that made the biggest difference.
So my question is ... is it really possible to get an even flat layer as described in the instructions? If so, how did you manage to do it?
