can you recommend a good AMD micro ATX mobo?
h20link
down at fraggle rock
I've got a micro atx case, it has a crappy mobo in it now, (only takes up to a 1ghz athlon or duron, 200 fsb, sdram). It's got an AGP slot and 3 pci, I'm looking to replace this mobo with something a little better, my budget is about $75....anything you guys recommend?
my friend has the same mobo, he's had probs with it so i figured i'd hunt around for something else.
Angry
So far the best is the Epox 8KHM DDR kt266a 4x AGP and 2-3 PCI and onboard sound.
And I think this should be in the AMD Motherboards section..but oh well.
There are others but no overclocking....and crap oboard graphics.
And its also around $75 on pricewatch.com (have to search for it)
h20link
h20link
that shuttle's okay but i'm looking for something with an agp slot, (gotta stay away from onboard graphics) thanks anyways...
i was gonna post in amd mobos section but there's no section of just motherboards. I didn't want to post it in one company's mobo thread and not get a response.
I will check out that other mobo, though. thanks.
h20link
h20link
okay well I am a fool I didn't scroll down in the amd mobo section. I'll move it over there, mods delete this if you want.....every time i try to delete my own thread i get some error page.
ThePunkGeek
Ontario Canada
well if you go to a ddr board it will cost more money better performace tho. are you wanting to stay with a sdr board sense you already have ram?
