Can you use a AC compressor insted of a fridge compressor?
FIRESTARR357
I am new to phase change cooling still learning all i can. I was wondering if i could use a AC compressor insted of a fridge compressor. Also whats the differance between the 2 and will i need to do any thing differant? Thx for the input for the newb lol
FIRESTARR357
FIRESTARR357
Well i dunno if this is dumb or not lol still trying to figure this out, could you use a Car AC compressor? also i need a guide that explains the way to hook all this up i went to phase-change but there guide did not explain everything i needed so does any one know where there is a better one , or post or suttin . thx guys
Warlord2
Bakersfield,CA
well I suppose you can use a car AC compressor but you will need quite a big motor to turn it. I wouldnt waste time messing with it, just find a compressor off a fridge or dehumidifier.
FIRESTARR357
FIRESTARR357
Well i went in the attic and i cut out the compressor from my old mini fridge, how ever i dunno but if i plug it in should it make some kind of noise or does it have to have refridgerant in it ? because i plugged it in and it did not make a sound? is it dead?
FIRESTARR357
FIRESTARR357
Yes it was. there where 2 wires when i took it out one to the plug and one that went in the fridge god knows where lol. So i cut the one that went into the fridge to get the compressor out. I did not think it matterd since it had a plug? could that be whats wrong? I dunno where the wire went but it went into the fridge so unless i smashed the fridge apart i could not see any way of getting it out and like i said the plug wire was fine?
FIRESTARR357
FIRESTARR357
Hey good looking man it worked i jumped them and bam it came on. Cool maybe i will do suttin with it too after all. Thx for the help guys :D
