cannot go more than 8.5
Fermium
I guys, I got problem pushing my multiplier more than 8.5 ... please help me.
I'm using hardware as below. with a Duron 750... after unlock my CPU... I manage to set the multiplier till 8.5... but when I set it to 9.... when boot... it show 100X7.0 ..which is only 700MHz.... what wrong with it?
to unlock my chip... I join all the circuit at L1... is that all i need to do? did I miss anything?
beside temp of CPU and stability.... what else should I pay attention to when OC?
thanks
Epox 8KTA3 (Max 120FSB)
128 Kingtons
MSI Geforce2 MX 32Mb (the chip is quite hot)
Duron 750MHz
If you connected the L1's with a pencil, you could try to redo it. I had a similar problem the first time I unlocked my duron, but after redoing the penciltraces, it worked out ok.
Thanks Justy303!
Thanks Bender.
I guess that's the problem I'm facing. I did the L1 connection again and I was manage to go beyond 8.5.... but good thing doesn't last. after some effort of OC... and I face the same problem again. so I tried to connect the L1 again... but it seem not working this way.
here is something I planned to do... what do u guys think? pls give me some opinion and suggestion.
I believe that it;s still something wrong with the L1 connection. I would like to remove that pencil connection with eraser and redo it again... would that be possible? will it turn up to be a short curcuit( means all the 8 points connect to each other bcoz of pencil everywhere?
Thanks for your time and knowledge.
for a permanent fix on the L1 bridging I'd clean it with acetone and alcohol then invest in some defogger repair paint from your local auto store
apply that with a needle or other small tool, make sure the paint trails are touching, let the paint settle for a day to make sure and you should have a permanent fix for your O/Cing needs
I used a piece of solder wire and cliped it with wire cutters for a sharp point and rubbed it in............ works great.
Duron 800 @ 1000
Stock HSF
Idle 55
Load 63
