Hi everyone,
I would appreciate any help at all with regards overclocking my E8400 3.00Ghz CPU on a P35-DS3R motherboard. As most of you will know, these chips are supposed to be fantastic overclockers. However, I have had absolutely no success at all. I've searched all over the net for tips, guides, settings etc with no luck. I'm told it should overclock to 3.6Hz easy with only a simple bump on the FSB from 333 to 400, but again no joy.
I've tried all sorts of settings, attempting to isolate exactly which setting is causing the failure for the O/C to past POST, and it seems if I set the FSB to ANYTHING except 333Mhz it fails to POST, motherboard hard resets and all BIOS settings revert to default.
I know my way around my PC, but I'm a total newbie when it comes to overclocking so I would really really appreciate any help you can offer on this as I feel I've tried pretty much everything and feeling pretty dejected as I don't know what else to do, or why it won't work.
My Details are as follows:
Gigabyte P35-DS3R rev 2.1
Core 2 Duo E8400 3.0Ghz
4*1GB Crucial 800Mhz RAM (2 sets of TWIN2X2048-6400C4 4/4/4/12 2.1v)
512Mb Nvidia GeForce 8800gt (PCI-E)
M-Audio 2496 PCI Soundcard
Win 7 32Bit
I've posted some photos below (sorry for the blurriness) of the furthest I've got in terms of adjusting settings towards an O/C. With these settings I can boot into Windows no problem. However, the final piece of the puzzle, upping the FSB, causes MB to crash before POSTing.
Thanks a million in advance for any suggestions on what I'm doing wrong here!!
James
Win 7 32Bit
- I have checked that I can change 'CPU CLOCK HOST CONTROL' to 'Enabled' and still boot ok, and I can, as long as I set the FSB at 333. Anything above or below that crashes the system.
- When I've tried changing the FSB to recommended 400Mhz for a 3.6gz Overclock (9x400), I of course adjust the system memory multipler to 2.00 (2x400Mhz FSB = 800Mhz for the RAM as rated).
- I've also tried the overclock with the memory timings loosened to 5/5/5/18, but no luck.
- I've tried different voltages on the CPU from 'normal' up to 1.35 which is probably way excessive, but even then it still does not get me past POST. I've also tried setting EIST to 'disabled' along with the other options on that BIOS screen. These settings boot fine, except again when I change the FSB
- I've tried setting the PCI-E Express Frequency to 'manual' - 100Mhz as this has been suggested on other posts, but didnt seem to make any difference.
James
