- Dec 4, 2008
Let' try this again for 3.60GHz
Advanced BIOS Features
DISABLE these 3:
CPU Enhanced Halt C1E
CPU Thermal Monitor
CPU EIST Function
Robust Graphic Booster: AUTO
CPU Clock Ratio: 9x
CPU Host Clock Control: ENABLED
CPU Host Frequency: 400
PCI Express Frequency: 101
CIA2: Disabled
Performance Enhance: Standard
System Memory Multiplier SPD: 2.00
Dram Timing Selectable SPD: MANUAL
then manually input these values
CAS Latency Time: 4
DRAM RAS to CAS: 4
DRAM RAS Precharge: 4
Precharge Delay: 12
System Voltage Control: MANUAL
DDR2 OverVoltage Control: +.3v
PCI-E OverVoltage Control: +.1v
FSB OverVoltage Control: +.2v
(G) MCH OverVotage Control: +.2v
CPU Voltage Control: AUTO
Then give me a screenshot similarlly looking like the one below while running Prime
(mine also uses 4 sticks of rams)
A few values need to be changed for 4GHz
DISABLE these 3:
CPU Thermal Monitor
CPU EIST Function
CPU Clock Ratio: 9x
CPU Host Frequency: 445
CIA2: Disabled
CAS Latency Time: 5
DRAM RAS to CAS: 5
DRAM RAS Precharge: 5
Precharge Delay: 15
FSB OverVoltage Control: +.2v....or try +.3v
(G) MCH OverVotage Control: +.3v
CPU Voltage Control: 1.41v
...also screenshot please.
DISABLE these 3:
CPU Thermal Monitor
CPU EIST Function
CPU Clock Ratio: 9x
CIA2: Disabled
CAS Latency Time: 4
DRAM RAS to CAS: 4
Precharge Delay: 12
DISABLE these 3:
CPU Thermal Monitor
CPU EIST Function
CPU Clock Ratio: 9x
CIA2: Disabled
CAS Latency Time: 5
DRAM RAS to CAS: 5
Precharge Delay: 15
