- Jan 3, 2005
- Guildford, England
Hi,
I have just built a new pc:
Asrock fatality z170 itx m/b
6700k
32gb ddr4 corsair vengeance
Samsung 951 nvme
And 1tb Samsung 840 evolution (been sat in my draw for a while)
Windows 10 is successfully installed on the 951, however I cannot see the 840 in Windows disk management at all! (bios thinks the sata port is empty)
I have tried plugging it into 3 different sata ports.
Bios is set to ahci, I have also set the sata port to be a solid state drive.
Csm is off and S. M. A. R. T is on.
The windows 10 installation software can see the 840,it let's me create and format a new partition, but it still doesn't appear at all when I reboot to Windows.
I have the Samsung drive magician software installed, that also doesn't see the drive.
I am out of ideas I would assume the motherboard or drive is daily if windows setup couldn't see it.
Thanks in advance for any ideas.
6700k
Samsung 951 nvme
