Make sure you are running the 1.33 Far Cry patch.
Check the punkbuster box if you connect to a punkbuster enabled server and update your punkbuster installation with PBweb.exe from
www.evenbalance.com.
Disable single player cheats. Multiplayer will not work with -devmode on the command line.
Only connect to low ping servers. (ping<100)
Make sure you have the same version of the map that is running on the server.
CD Key in use or CD key invalid is a common problem. You will get that if you were recently booted from a server because the server holds the key for a short time. Usually, just trying to connect again will work.
