- Feb 7, 2013
A while ago I got the bad idea that maybe a newer BIOS version would somehow unlock sys fan settings below 50% for me so I updated my BIOS. Long story short, the update process went wrong I was stuck with a PC that would not boot. After a whole day of trouble shooting and excellent support from MSI I got it to work again.
But some issues remain:
1) My PC will not always boot on the first try. It rarely (and never more than) takes 3 attempts to boot. The PC will power on, power off and power on again and then finally POST and successfully boot.
2) I can't access the BIOS anymore directly (F2, DEL, ...). I have to use advanced start up options out of windows 10 to get into it. Did MSI change the keys for that to a key not known to me? Previously it was F2.
3) Not sure if related to the BIOS update, sometimes my USB mouse and keyboard will stop working. I have to reboot the PC to get them to work again. I directly connected them to the front ports of my case, I have USB extension cables, the issue remains. If I then connect my wireless mouse/keyboard combo they work flawlessly. Recently I noticed that the "Device connected / disconnected" sound occurs from time to time without the noticeable disconnect of any device (a friend of mine reported the same. I disabled that power saving feature in windows 10 that would allow to disconnect USB devices with no success.
To 1) a friend of mine said he had the same with a failing SSD. Any chance to check?
To 3) I suspect it's the G15 keyboard I inherited from my roommate. He never had any issues but I only started to notice after I got his keyboard.
Do you guys have any information / input for me? Besides the obvious never touch a running system regarding the BIOS update
Specs are in the sig.
