V
viking
Guest
ok lets start from the beging i was playing unreal tournament computer got pretty slow so i shut down the computer after that the computer didn't want to boot back up i got nothing but a black screen and i could hear the power supply making a high pitch noise so i took out the power supply tried it in second computer i get the same black screen put another power supply in a 250watt ,computeer boots get through the high point crap then it frezzes. i can get into the high point bios and the bios , just before i get to the dual boot option it frezzes i never get to see the option where it ask me when winme or win2000 it stops right before that did i fry my board when power supply went bad or do i just need 300watt power supply to boot this system oh BTW i disconted power from everything but hard drives and cpu fans and It Did the samething useing the 250 watt power supply any ideas
thanks
viking
____________________________________________________
AMD T-BIRD K7 1.1GHZ @ 1210 MHz
Alpha's PEP66
ABIT KT7-RAID VIA KT133 ( Bios v,yh) (VIA 4-in-1, 4.30)
Voltage Mod on Borad Can Go up to( 2.70v)
Multi Boot WinMe,Win2000,WinXp
2 Sticks Of CORSAIR CM654S256-133C2 32X64 PC133 256MB CAS2 SDRAM =512MB
ELSA GLADIAC ULTRA 64MB AGP DDR GEFORCE2 (D.Divers 1101)
SOUNDBLASTER LIVE VALUE PCI
PLEXTOR 40X-16X-10X- EIDE INTERNAL
2-IBM 30.0GB EIDE ULTRA ATA/100 LP DESKSTAR 7200RPM 75GXP On Raid O
IOMEGA ZIP 100MB IDE INTERNAL
400 Watt Power Supplies Runs System
250 Watt Power Supplies Runs 8 Case Fans
thanks
viking
Alpha's PEP66
